Hope someone will stay on this with me because I have a list of things here
I use Zorin OS 16Lite. I truly appreciate that a newbie like me gets help from you. Image links: https://controlc.com/e9e29984
1- Can I increase Edge's scrollbar width?
On Windows, you would have the regs where you would define it and it will have an effect in Chromium browsers. I know about editing the gtk.css but it has a lot of line codes and wasn't able to find the afferent one for scrollbars. I did edit that file and made some changes to the scrollbar's width which had an effect in Zorin but not in Edge, it seems it's different from Windows.
2- Move the bottom bar Edge tabs on the second screen monitor (like in Windows):
In Windows when you use dual monitor, when you move a tab on the second monitor, it will also move it on the panel. Here in Zorin, even if for example Edge is on the second monitor, it's still displayed on the first one:
3- On Windows, once I would set up my programs, find the final state of the setups, I would make a clone of the system on a HDD and if it would break, then I would have just install that image and everything was working. I was using it mainly for fatal system crash, just like I would have gone back in time. There was a program called DeepFreeze which was doing the same thing for Windows. Is there anything like that in ZorinOS, to freeze my OS now exactly how it is and just restore it if an update goes wrong or something?
4- Why does it have 2 title bars, one blue and one black.
Black -> text editor, Blue -> OpenOffice. Can I just have one color and title bar, the one from the text editor's?
5- Copy-paste in Online Accounts. I am using Google drive in Online Account and each time I copy paste something from it on Desktop, the whole name of the file/folder changes on Desktop. In that screenshot, the name of the file in Google Drive is test.txt but once I paste it on my Desktop, it becames that long characters name. Not sure if it affects the functinality of the files yet.
6- Desktop icons. If I make shortcuts to apps, their icons are fine as long as they are on Desktop. Once I move them into a folder that resides on the Desktop, it becomes what's visible in the screenshot, a white icon. Can I have nice icons just like they are on Desktop, in the folder?
7- Can I make any newly installed app automatically have a desktop shortcut? Just like in Android, when you install an app, you would just go and find it on the screen.
8- Change this black selected icon. When I select a desktop icon, it becomes black and ugly, including the text. Can you let me know what do I need to change in gtk.css to have it nice, as in Windows when it's selected? I am using the Zorin Blue Dark theme btw.
9- Do you know any program that automatically hides the cursor when typing?
On Windows I was using AutoHideMouseCursor_x64.
Wasn't able to find something similar in Linux.
10- Scrolling speed: since I moved to ZorinOS I noticed a change in scrolling distance, in browsers. I have to use the mouse middle scroll button and make quite a few complete rounds to be able to scroll in the same spot Windows would take me with 1-2 scrolls tops. Hope it's clear enough. Can I change that somewhere? Wasn't able to find it in Settings.
Thanks in advance for any help that I'd get
