Very slow and lag
Hello I just bought 18 pro , my laptop : i5 8250u 16gb ram ,512gb ssd
It runs very slow and laggy with zorin 18 , it takes to much time when try run anything, even browser. I switch from windows 25h2 to zorin , windows was like run smoother. Any help ?
Hiya,
Let's take a look at you video card and driver.
Open the terminal and type(copy/paste);
sudo apt install inxi
inxi -Ga
Please post the output.
Graphics:
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0bda:5689
class-ID: 0e02 serial: 0x0001
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6
compositor: gnome-shell v: 46.0 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x38ed built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa
v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel UHD Graphics 620 (KBL GT2) device-ID: 8086:5917 memory: 7.57 GiB
unified: yes
Fixed most iusses when switch to xorg
Which issue(s) is left?
The lag ui is not anymore and it load now even quicker
Do you have Dualboot with Windows? If yes, please disable fast startup there.
And during use of Linux it can help to disable secure boot and fast boot in BIOS.
No just only installed there zorin, security boot is disable .
@l3allermann82 Can you say which slow/lag issues you still face, since switching to Xorg?
If we know, we may then be able to help you some more.
Now seems works perfekt after switch to xorg.
In that case I marked your "switch to xorg" post as :white_check_mark:Solution. Zab
