I'm having some severe video issues after rebooting:
the right half of my primary monitor is showing vertical bars instead of the desktop.
these bars don't show up in screenshots.
they appear on my primary monitor (displayport) but will switch to the hdmi monitor if I reboot with only that monitor plugged in.
I hadn't rebooted in a while, and it looks like the kernel updated to 7.0.0-30, but I tried -29 and -28 and have the same issue.
display is extremely unstable and changing any display settings will usually lock everything up.
staying on the broken version of the desktop, things will lock up after a while (I'm in a recovery mode now)
Any ideas? I've been using Zorin for a while, but I'm still a Linux novice. I'm guessing some issue with my video card driver that I either need to reinstall or roll back? Thank you in advance!
Some system details (again, in recovery mode):
OS: Zorin OS 18.1 x86_64
Kernel: 7.0.0-30-generic
Uptime: 1 min
Packages: 2651 (dpkg), 144 (flatpak)
Shell: bash 5.2.21
Resolution: 2560x1440
DE: GNOME 46.0
WM: Mutter
WM Theme: ZorinPurple-Dark
Theme: ZorinPurple-Dark [GTK2/3]
Icons: ZorinPurple-Dark [GTK2/3]
Terminal: gnome-terminal
CPU: AMD Ryzen 7 5800X3D (16) @ 4.81
GPU: AMD ATI Radeon RX 6800/6800 XT
Memory: 2455MiB / 31987MiB
To me, these sound like probable Panel Self Refresh issues.
But, as a quick test, can you try lowering your refresh rate on your monitor to see if this results in the screen displaying normally? If it does, you can choose to use a bit lower refresh rate or try a Grub parameter to correct for the display.
Another test is from the Login screen, select to load on Zorin On Xorg (X11) instead of Wayland and see if it works on X11.
It looks like I'm having issues in both xorg and wayland, but I can only switch between them in recovery mode (no video issues in this mode), but in a regular session that gear on the login screen is always hidden under the video artifacts.
I have one monitor at 60hz and the other was at 59.95hz with no option at 60hz. They used to be at 120hz, but updates or reboots seem to reset me to 60hz periodically.
Yes, Forpli was on top of it. The moment I saw his post, I knew that was it.
You can hold that package long term. But eventually, since Firmware is tied to Kernel updates, it would need to get addressed. By that time, you may be on Zorin OS 19... Or that firmware bug fix released.
