VLC media player no input codec>hardware to set VAAPI for amd processors
Hi, I'm new here and new to Linux.I installed zorin os 18 about 2 months ago. I have a GMKtec nucbox m7 with amd ryzen cpu with Radeon 680m intergrated gpu. I'm having problems with hardware accelerating using gpu in Handbrake. Brave AI says to click tools> preferences>all>input codecs>hardware and check VAAPI for amd processors for hardware acceleration. I installed and uninstalled vlc several times with different versions. Installed vainfo thru terminal and still don't have the Hardware tab coming up. Any help wound be appreciated.
Maybe disable Hardware Acceleration? And can You say exactly what CPU You have? Depending how new it is maybe a newer Kernel could help for better Hardware Support.
