Can we do both? Yours gave me the initial working solution, and it should still be considered valid for installing Classic.
If you want to do another response post combining both, that should definitely be the solution.
We don't get paid for solutions.
But the point of the solution is that it is directly linked in the O.P. leading any future readers right to the post that contains the actual solution, saving them time and searching.
Good question.
I've never figured it out how to select multiple postings as solutions.
It happened once but I suspect it was a bug in the Discourse server.
Yes, that happened when posts were moved, creating a situation where both posts marked as solved were technically in different threads at that moment.
Is this a typo?
Do you mean Waterfox Classic.
You might want to give FlashPeak Slimjet a go - it is really fast because it has built in adblocker and is not corporately owned.
https://www.slimjet.com/
I moved away from Firefox because it no longer supports ALSA (Advance Linux Sound Architecture).
Thank you for that post as you reminded me to add my extensions in Vivaldi .... LOL
Yep, messed up there. Yes, I mean Waterfox XD
