Help I cannot access terminal and programs, also this happened to my icons, (when I try to launch program it says input/output error) (when I try to use terminal it says “command not found” to all commands)
Have you done an uninstall commands or sudo apt autoremove
recently?
Are you using a custom icon theme (just to role that out)?
