What exactly is the problem? I am waiting for your solution suggestions. Thank you in advance :)
root@saykotek-Swift-SF314-54:/home/saykotek# sudo apt update && sudo apt upgrade
Aynı: 1 Index of /ubuntu jammy InRelease
Aynı: 2 Index of /ubuntu jammy-updates InRelease
Aynı: 3 Index of /ubuntu jammy-backports InRelease
Aynı: 4 Index of /ubuntu jammy-security InRelease
Aynı: 5 https://ppa.launchpadcontent.net/gnome-terminator/ppa/ubuntu jammy InRelease
Paket listeleri okunuyor... Bitti
Bağımlılık ağacı oluşturuluyor... Bitti
Durum bilgisi okunuyor... Bitti
Tüm paketler güncel.
N: '/etc/apt/sources.list.d/' dizinindeki 'gnome-terminator-ubuntu-ppa-jammy.list.save' dosyası geçersiz bir dosya uzantısı olduğu için yok sayılıyor
Yükseltme hesaplanıyor... Bitti
0 paket yükseltilecek, 0 yeni paket kurulacak, 0 paket kaldırılacak ve 0 paket yükseltilmeyecek.
You need to tell us what led to this and add some information to what the issue is.
It would also help if translated to English. I have done online translation for you here:
N: The file 'gnome-terminator-ubuntu-ppa-jammy.list.save' in the '/etc/apt/sources.list.d/' directory is being ignored because it has an invalid file extension Reading packing lists... Over Creating a dependency tree... Over Reading status information... Over Calculating the upgrade... Over 0 packages will be upgraded, 0 new packages will be installed, 0 packages will be removed, and 0 packages will not be upgraded. N: The file 'gnome-terminator-ubuntu-ppa-jammy.list.save' in the '/etc/apt/sources.list.d/' directory is being ignored because it has an invalid file extension root@saykotek-Swift-SF314-54:/home/saykotek#
To deal with the PPA issue I would follow the first part of the solution given here:
To be specific:
sudo rm /etc/apt/sources.list.d/*.disable
