It looks like just this entry needs to be removed from /etc/apt/sources.list.d directory.
OK it's deleted ......
mike@mike-ROG-Strix-G731GT-G731GT:~$ ls /etc/apt/sources.list.d
apandada1-ubuntu-brightness-controller-jammy.list
camel-neeraj-ubuntu-sysmontask-jammy.list
gerardpuig-ubuntu-ppa-jammy.list
linuxuprising-ubuntu-shutter-jammy.list
mati75-ubuntu-gimp30-jammy.list
tuxinvader-ubuntu-lts-mainline-longterm-jammy.list
zorin.list
zorin.list.save
zorinos-ubuntu-apps-jammy.list
zorinos-ubuntu-drivers-jammy.list
zorinos-ubuntu-patches-jammy.list
zorinos-ubuntu-stable-jammy.list
Round Two:
sudo apt clean && sudo apt autoclean && sudo apt autoremove
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt clean && sudo apt autoclean && sudo apt autoremove
[sudo] password for mike:
Reading package lists... Done
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
nemo : Depends: xapp but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Now let's run
sudo apt remove --purge xapp nemo
Or
sudo apt --fix-broken install
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt remove --purge xapp nemo
Package 'xapp' is not installed, so not removed
nemo-fileroller : Depends: nemo (>= 4.6) but it is not going to be installed
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt --fix-broken install
Correcting dependencies... Done
cinnamon-common cjs gir1.2-caribou-1.0
gir1.2-cmenu-3.0 gir1.2-ecal-2.0 gir1.2-ical-3.0
gir1.2-keybinder-3.0 gir1.2-meta-muffin-0.0
gir1.2-nemo-3.0 gir1.2-timezonemap-1.0
libcaribou-common libcaribou0 libcjs0
libkeybinder-3.0-0 libmozjs-78-0 libtimezonemap-data
libtimezonemap1 metacity-common python-tinycss2-common
python3-pampy python3-pyinotify python3-tinycss2
xapp
xapp
0 upgraded, 1 newly installed, 0 to remove and 17 not upgraded.
2 not fully installed or removed.
Need to get 37.9 kB of archives.
After this operation, 168 kB of additional disk space will be used.
Get:1 Index of /ubuntu jammy/universe amd64 xapp amd64 2.2.8-1 [37.9 kB]
Fetched 37.9 kB in 1s (27.4 kB/s)
(Reading database ... 383070 files and directories current
ly installed.)
Preparing to unpack .../xapp_2.2.8-1_amd64.deb ...
Unpacking xapp (2.2.8-1) ...
dpkg: error processing archive /var/cache/apt/archives/xap
p_2.2.8-1_amd64.deb (--unpack):
trying to overwrite '/etc/xdg/autostart/xapp-sn-watcher.d
esktop', which is also in package xapps-common 2.4.1-unsta
ble-202211161052~ubuntu20.04.1
/var/cache/apt/archives/xapp_2.2.8-1_amd64.deb
Ok... what is your output for
sudo apt update
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt update
Hit:1 Index of /ubuntu jammy InRelease
Get:2 Index of /ubuntu jammy-security InRelease [110 kB]
Get:3 Index of /ubuntu jammy-security InRelease [110 kB]
Hit:4 Index of /apandada1/brightness-controller/ubuntu jammy InRelease
Hit:5 Index of /ubuntu jammy InRelease
Hit:6 Index of /stable/ jammy InRelease
Ign:7 Index of /camel-neeraj/sysmontask/ubuntu jammy InRelease
Hit:8 https://screenrec.com/download/ubuntu stable InRelease
Hit:9 Index of /patches/ jammy InRelease
Hit:10 Index of /gerardpuig/ppa/ubuntu jammy InRelease
Hit:11 Index of /apps/ jammy InRelease
Ign:12 Index of /linuxuprising/shutter/ubuntu jammy InRelease
Hit:13 Index of /drivers/ jammy InRelease
Hit:14 Index of /mati75/gimp30/ubuntu jammy InRelease
Get:15 Index of /ubuntu jammy-updates InRelease [119 kB]
Ign:16 Index of /tuxinvader/lts-mainline-longterm/ubuntu jammy InRelease
Hit:17 Index of /ubuntu jammy-backports InRelease
Hit:18 Index of /zorinos/apps/ubuntu jammy InRelease
Hit:19 Index of /zorinos/drivers/ubuntu jammy InRelease
Hit:20 Index of /zorinos/patches/ubuntu jammy InRelease
Hit:21 Index of /zorinos/stable/ubuntu jammy InRelease
Err:22 Index of /camel-neeraj/sysmontask/ubuntu jammy Release
404 Not Found [IP: 185.125.190.80 443]
Err:23 Index of /linuxuprising/shutter/ubuntu jammy Release
Err:24 Index of /tuxinvader/lts-mainline-longterm/ubuntu jammy Release
W: Skipping acquire of configured file 'universe/binary-amd64/Packages' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/binary-i386/Packages' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/i18n/Translation-en_PH' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/i18n/Translation-en' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/Components-amd64.yml' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-48x48.tar' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-64x64.tar' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-64x64@2.tar' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/cnf/Commands-amd64' as repository 'Index of /ubuntu jammy InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: https://screenrec.com/download/ubuntu/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: Skipping acquire of configured file 'universe/binary-i386/Packages' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/binary-amd64/Packages' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/i18n/Translation-en_PH' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/i18n/Translation-en' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/Components-amd64.yml' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-48x48.tar' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-64x64.tar' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/dep11/icons-64x64@2.tar' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'universe/cnf/Commands-amd64' as repository 'https://screenrec.com/download/ubuntu stable InRelease' doesn't have the component 'universe' (component misspelt in sources.list?)
E: The repository 'Index of /camel-neeraj/sysmontask/ubuntu jammy Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'Index of /linuxuprising/shutter/ubuntu jammy Release' does not have a Release file.
E: The repository 'Index of /tuxinvader/lts-mainline-longterm/ubuntu jammy Release' does not have a Release file.
Looks like all those Items in blue are respo's I deleted
This is strange... even the items from your sources.list are reporting a lack of a release file...
Did you modify the sources.list file at all? Or only delete items from /etc/apt/sources.list.d?
I did notice that the CDROM zorin OS entry still says 16.
Only from list.d ...... didn't do anything that I know of in sources.list ..... but these were all done using Nemo at that time as it was set as default until I just changed it to Thunar
First, please clarify that the upgrader did fully run:
cat /etc/lsb-release
If the output shows:
DISTRIB_ID=Zorin
DISTRIB_RELEASE=17
DISTRIB_CODENAME=jammy
DISTRIB_DESCRIPTION="Zorin OS 17"
Then proceed with the below:
Can you please elevate to root, then open your /etc/apt/sources.list file in a text editor. Highlight everything (Or Select All) and delete all lines. Black it out.
Once done,
copy and paste the below into it.
#deb cdrom:[Zorin-OS 17 Core Beta 64bit]/ jammy main restricted
deb http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy main restricted
## distribution.
deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates main restricted
deb http://us.archive.ubuntu.com/ubuntu/ jammy universe
# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy universe
deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates universe
## security team.
deb http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy multiverse
deb http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-updates multiverse
deb http://us.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
# deb-src http://us.archive.ubuntu.com/ubuntu/ jammy-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu jammy-security main restricted
# deb-src http://security.ubuntu.com/ubuntu jammy-security main restricted
deb http://security.ubuntu.com/ubuntu jammy-security universe
# deb-src http://security.ubuntu.com/ubuntu jammy-security universe
deb http://security.ubuntu.com/ubuntu jammy-security multiverse
# deb-src http://security.ubuntu.com/ubuntu jammy-security multiverse
Save the file.
Once done, run
sudo apt update
and relay if it is showing errors like "does not have a release file"
mike@mike-ROG-Strix-G731GT-G731GT:~$ cat /etc/lsb-release
DISTRIB_ID=Zorin
DISTRIB_RELEASE=17
Now onto the rest .....
Get:95 Index of /ubuntu jammy-backports/multiverse amd64 c-n-f Metadata [116 B]
Get:25 Index of /ubuntu jammy/main amd64 DEP-11 Metadata [423 kB]
Sorry about that mistake I installed all three of this respos's .... just checked my list ..... I did install all 3
Can you go ahead and remove the repos for Shutter, Sysmontask and TuxInvader kernel?
zorin.list
zorin.list.save
sudo apt update
I went ahead and viewed the up grade able at the end of sudo apt update to see what they were ....
Hit:1 Index of /ubuntu jammy-security InRelease
Hit:2 Index of /ubuntu jammy InRelease
Hit:3 Index of /ubuntu jammy-updates InRelease
Hit:4 Index of /ubuntu jammy-backports InRelease
Hit:5 Index of /stable/ jammy InRelease
Hit:6 Index of /apandada1/brightness-controller/ubuntu jammy InRelease
Hit:7 Index of /gerardpuig/ppa/ubuntu jammy InRelease
Hit:8 Index of /patches/ jammy InRelease
Hit:9 Index of /mati75/gimp30/ubuntu jammy InRelease
Hit:10 Index of /apps/ jammy InRelease
Hit:11 Index of /zorinos/apps/ubuntu jammy InRelease
Hit:12 Index of /drivers/ jammy InRelease
Hit:13 Index of /zorinos/drivers/ubuntu jammy InRelease
Hit:14 Index of /zorinos/patches/ubuntu jammy InRelease
Hit:15 Index of /zorinos/stable/ubuntu jammy InRelease
17 packages can be upgraded. Run 'apt list --upgradable' to see them.
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt list --upgradable
Listing... Done
gegl/jammy 1:0.4.46-1~ubuntu22.04.1~ppa1 amd64 [upgradable from: 1:0.4.46-1~ubuntu20.04.1~ppa4]
gimp-data/jammy,jammy 2.99.16-1~ubuntu22.04.1~ppa3 all [upgradable from: 2.99.16-1~ubuntu20.04.1~ppa5]
gimp/jammy 2.99.16-1~ubuntu22.04.1~ppa3 amd64 [upgradable from: 2.99.16-1~ubuntu20.04.1~ppa5]
libbabl-0.1-0/jammy 1:0.1.106-2~ubuntu22.04.1~ppa1 amd64 [upgradable from: 1:0.1.106-2~ubuntu20.04.1~ppa1]
libgegl-0.4-0/jammy 1:0.4.46-1~ubuntu22.04.1~ppa1 amd64 [upgradable from: 1:0.4.46-1~ubuntu20.04.1~ppa4]
libgegl-common/jammy,jammy 1:0.4.46-1~ubuntu22.04.1~ppa1 all [upgradable from: 1:0.4.46-1~ubuntu20.04.1~ppa4]
libgimp-3.0-0/jammy 2.99.16-1~ubuntu22.04.1~ppa3 amd64 [upgradable from: 2.99.16-1~ubuntu20.04.1~ppa5]
libhwy1/jammy 1.0.2-4~ubuntu22.04.1~ppa1 amd64 [upgradable from: 1.0.2-4~ubuntu20.04.1~ppa2]
libjxl0.7/jammy 0.7.0-5~ubuntu22.04.1~ppa1 amd64 [upgradable from: 0.7.0-5~ubuntu20.04.1~ppa1]
liblcms2-2/jammy 2.13.1-1~ubuntu22.04.1~ppa1 amd64 [upgradable from: 2.13.1-1~ubuntu20.04.1~ppa1]
liblcms2-utils/jammy 2.13.1-1~ubuntu22.04.1~ppa1 amd64 [upgradable from: 2.13.1-1~ubuntu20.04.1~ppa1]
linux-generic-hwe-20.04/jammy-updates,jammy-security 5.15.0.94.91 amd64 [upgradable from: 5.15.0.92.102~20.04.49]
linux-generic-hwe-22.04/jammy-updates,jammy-security 6.5.0.17.17~22.04.9 amd64 [upgradable from: 6.5.0.15.15~22.04.8]
linux-headers-generic-hwe-20.04/jammy-updates,jammy-security 5.15.0.94.91 amd64 [upgradable from: 5.15.0.92.102~20.04.49]
linux-headers-generic-hwe-22.04/jammy-updates,jammy-security 6.5.0.17.17~22.04.9 amd64 [upgradable from: 6.5.0.15.15~22.04.8]
linux-image-generic-hwe-20.04/jammy-updates,jammy-security 5.15.0.94.91 amd64 [upgradable from: 5.15.0.92.102~20.04.49]
linux-image-generic-hwe-22.04/jammy-updates,jammy-security 6.5.0.17.17~22.04.9 amd64 [upgradable from: 6.5.0.15.15~22.04.8]
Frog... We are gettin' places, now. Hoppin'.
Let's run (this one may not show an output):
sudo dpkg --configure -a
sudo apt upgrade
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of nemo:
nemo depends on xapp; however:
Package xapp is not installed.
dpkg: error processing package nemo (--configure):
dpkg: dependency problems prevent configuration of nemo-fileroller:
nemo-fileroller depends on nemo (>= 4.6); however:
Package nemo is not configured yet.
dpkg: error processing package nemo-fileroller (--configure):
nemo
nemo-fileroller
mike@mike-ROG-Strix-G731GT-G731GT:~$ sudo apt upgrade
