Using Zorin OS 18.1 Pro. Have discover last weeks that when printer is running, cant use browser. Same in Brave and Chrome.
Hello and welcome,
Do you have dual boot ?
if no, does secure boot is disable from your BIOS ?
i f yes, disable fast boot in windows power management settings.
We will also see if you are on Xorg or Wayland, could you give me the output of
echo $XDG_SESSION_TYPE
- Are Secure Boot and Fast Boot in BIOS disabled?
- If Windows is still installed: Is Fast Start-Up in Windows disabled?
- Did You tried it with disabled Hardware Acceleration in the Browsers?
- Are the Browsers installed as Flatpak or .deb/APT Package?
- Is The Printer connected via Cable or wireless?
what is your printer model ?
