Can someone explain this one - I'm getting software updates from the Software Updater AND Software. Weird thing is they don't sync but actually show different updates????
One is from the repo, the other one is flat/snap.
So, I really need to keep tabs on both these places for updates?
Usually there's a popup telling you when there's a an update available, so you don't need to manual checking. The repo and the snap/flat is two completely different systems.
Thanks Storm - just didn't realize two separate systems . . .
