Hi, having a strange problem with ZorinOS 16 Pro. My Wifi adapter acts very weirdly. Sometimes, after startup or restart, it can't find my wifi. See only others' wifi.
But this problem is only on Linux. Having dual boot with W10 and there are no problems with this adapter.
My Wifi adapter is "TP LINK Archer T6e AC1300" (BCM4360 802.11 ac as seen on Additional drivers)
I removed my post because i thought it was the same wifi card as i have but i have a mini usb ac1300 and he has a ac1300 card.
I have the same adapter, V2
During the installation of Zorin OS Pro 16, I used it to download updates. After the reboot, the adapter was not detected.
I solved the problem like this: I connected the Internet via LAN and downloaded and installed the current driver in the "Drivers".
I don't see any problems with this adapter.
yep, I did the same but problems persist
The only difference between @alfacs and @Fryer1 is alfacs has Z16 Pro and Fryer1 has Z16 Core.
Whilst that itself should not be the cause of this, it may give others thinking about it a steer.
I bought the wifi adapter with an intel chip (AX200). That was the solution.
So, now, wifi works without any problems.
Ziyituod WiFi Card 3000Mbps Wireless Adapter with Bluetooth 5.1 Dual Band (2.4G/5G)
What was solution here another type a wifi card? I have Archer T9E ver. 1.0 but wifi is connect lost connect in loop. Using a cable to my LAN with switch.
sudo modprobe rtl8812au
and sudo apt-get install rtl8812au-dkms
I check in future when installing on a computer.
