i installed zorin and my pc and i cant connect to the wifi, when i search for wifi in the settings it says "wifi adapter not found"
(i ran lshw -c network for this) v
yeah that usually means the kernel just isnt loading a driver for the card yet. can you paste the output of these two?
lspci -nnk | grep -A3 -i net
lsusb
in my experience its often a realtek or broadcom chip that needs an extra package, but without the ids its just guessing. also say if this is a desktop with a usb dongle or a laptop wifi card.
Try using advanced options to boot into an older kernel such as 6.8
The iwlwifi driver for the wifi card should be included into zhe kernel. But it is not loaded correctly.
Do you have a Dualboot with Windows? Please disable fast startup in Windows power options, and disable fast boot in your BIOS.
Would you please post the terminal output of
rfkill list
, please?
Kernel 6.8 is not preinstalled on Zorin, but you could try to boot with the 6.17 or the previous 7.0 kernel kernel (you can select it in grub menu at Advanced options for Zorin, select the normal version there, not the recovery kernel).
If you need kernel 6.8 for your hardware, you can install it, but for iwlwifi you shouldn't need it. I read in a post of another user that the latest update to kernel 7.0.0-31 made problems with iwlwifi.
I'd take a look here:
https://askubuntu.com/questions/1525375/intel-9260-wireless-card-not-working-after-24-04-1-upgrade
Under ''resources'' from Your Screenshot should be more Output. Could You post that too please?
