Wifi Adapter not found after Kernel Update
Hi everyone, after the recent Kernel update to 6.17.0-23 it is possible that there is no handshake to the wifi peripheral, and i have no way to switch without a usb.
I am new to zorin and i see other people have the same problem as me, so fai i tried:
-Confirming secure boot is disabled
-looking for older kernel version in grub>advanced options
But in the latter case the versions only go back to 6.17.0-22, when i should go back to -20.
Do i have to take my pc to a LAN in order to download the older one? Get it to a stick? Is it hidden in another repo?
Thank you in advance. It has been a mild work inconvenience and i would really appreciate your help.
Hello and welcome,
you can install 6.17.0-20 like this
sudo apt install linux-image-6.17.0-20-generic
The dependencies will be installed automatically. Then in the next boot, select it in the grub menu.
This is the Kernel before -23. Does this not work, too? Could You post the Output of the Commands sudo lshw -C network and rfkill list please?
I can't see anything...
@IvanXVIII . You can upload images to your post using the "Upload" icon (7th from left) on the Reply box toolbar.
you have to set your update server to main here
and after do
sudo apt update && sudo apt upgrade && sudo apt autoremove
and after
If you have enabled a VPN please disable it if the terminal still shows errors. Then try it again.
