Wifi conect but not navigate mbp 4.1
Hello ?
restart and test? Never heard of updating causing the hotspot to stop working...
restarted the second cable conection does not work anymore
wifi conect but not navigate
changed usb local cabled conection 2 worked again
What is the terminal output for
apt search bcmwl-kernel-source
command not found
Hello?
It gave this as the output for apt search?
Are there typoes - did you copy and paste the line from the post above into terminal?
tried again: font code of linux driver for wifi board Broadcom 802.11 STA installed
now what ?
In terminal, run
iwconfig
And relay the output here.
io no wireless extensions
ens5 no wireless extensions
wls4 IEEE 802.11 ESSID:"Fernando Leiria-5G"
Mode:managed frequency:5,16 GHz Access Point: F4:54:20:94:75:BE
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
enx5e5284819ab5 no wireless extensions
Hmmm... Let's try:
sudo apt remove --purge bcmwl-kernel-source
Then immediately after, run:
sudo apt install firmware-b43-installer
Reboot - test wifi connection...
SUCESSO sucess HP HIP HIP HURRAE
2,4 GHz connect
5.0 GHz connect
cable 2 iphone connect
CONGRATULATIONS , I appreciate yours efforts!
