i installed zorin os lite on my dell laptop and ever since wifi has be disconneted
or turn off.wifi was working fine on windows , fedora .my computer like 10 years
old but it works on my brother comp that is a bit newer
What is the terminal output of
inxi -N
here is the output:
Card-1: Broadcom and subsidiaries NetXtreme BCM5755M Gigabit Ethernet PCI Express driver: tg3
Card-2: Broadcom and subsidiaries BCM4311 802.11b/g WLAN
This might help:
https://forums.linuxmint.com/viewtopic.php?f=53&t=232330
Thank you and Thank you My wifi is working Back
Hi, if the solution worked for you, you could tick on a "solution" box
in that message to mark it. This will help future visitors to find the solution if they are having the same issue.
It is also an option, but you can also tick the heart icon
in the message to thank the person who has offered the solution. It also make that message to stand out making it easier to find for the future visitors.
