Wi-Fi originally works after installation; after I restarted the computer, Zorin let me know that 'no network devices are available'. Now, i cannot access the internet. How do i make Wi-Fi available again?
OS version: Zorin OS 16 Lite
Dual boot with Windows 11
Do you know if there was there a OS Update (e.g. kernel update) before the restart?
There was an update before the restart, but the Wi-Fi worked after it. Only 2 hours after that did I restart the computer.
Just to clarify, I did not restart because of the update.
Noted. But you could have edited your previous post to say that instead of posting another.
Anyhow. Have a look at this for starters
wireless, 20.04
As you are dual-booting Windows, see the answer with 21 approvals. Re Fast Startup in Windows. Other answers may also be worth a look.
I have solved the issue myself. I need to enter the Secure Boot password during startup.
system
Closed
8 April 2022 10:54
7
