I found out I need to install the deprecated package net-tools in order to use the command ifconfig.
Running the command now results in a description and a list with 0 dropped packages. Are you interested in anything specific, or shall I copy the whole text from the laptop?
Details? Bring it on...
For ifconfig to work you have to install net-tools:
sudo apt-get install net-tools
This is odd because I just ran ifconfig without any trouble and without needing to install anything.
How could Ifconfig be missing?
@Aravisian I only know this because I had similar issues - can’t remember but think it might have been regarding the notebook as all desktops are on powerline adapters.
I'm back. Had to wait 13h after using up all the post I can do on the first day...
This is the result of ifconfig
wlp2s0: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether 4c:eb:bd:ba:85:01 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
Hmm...
Can you enter into terminal:
sudo nano /etc/network/interfaces
You should see
auto lo
iface lo inet loopback
Can you change that to:
auto lo
auto wlp2s0
iface wlp2s0 inet dhcp
Run in terminal
sudo systemctl enable networking
Reboot and check...
I had to wait another 8h after the last post. But that is fixed now
Somewhere in the wilds of the internet, I read yesterday that linux kernel 5.5 solves the problem. So I did a manual update to linux 5.5.0-generic following these instructions and now the wifi works again.
Thanks to everyone for the help.
And another
from me - once a post is marked as solution you can’t increase the LUV!
