Hola, acabé de instalar zorin OS lite en mi computador, pero no puedo conectar a internet (ni con WiFi ni con ethernet), agradecería una pronta solución.
What is the output of sudo lshw -c network
You have the correct 8169 driver but if rebooting doesn’t solve your problem then try the suggestion here: [SOLVED] No ethernet interface after upgrading to linux-lts-5.4.30-1 / Kernel & Hardware / Arch Linux Forums
Marked solution. 209
