WiFi unavailable on intel-7260 card
I am dual booting zorin and windows and while WiFi is functioning on windows, it doesn’t seem to work on zorin.
I have checked wlan is enabled in bios, disabled secure boot, updated software, but I can not seem to get the WiFi to work. I can confirm Bluetooth is working though.
You could check the ''Additional Drivers'' Tab in Software & Updates if there is a Driver offered.
Could You post the Output of the Commands sudo lshw -C network and rfkill list please?
Could you also make sure that in Windows that you have the "Fast Startup" option disabled? That can cause a lot of problems as well (even just for windows, frankly)
:~$ iwconfig
lo no wireless extensions.
enp59s0 no wireless extensions.
:~$ sudo lshw -c network
   product: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:3b:00.0
   logical name: enp59s0
   version: 1f
   serial: a4:bb:6d:6c:c0:0e
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.14.0-36-generic firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=twisted pair
   resources: irq:17 ioport:3000(size=256) memory:9a504000-9a504fff memory:9a500000-9a503fff
*-network UNCLAIMED
description: Network controller
product: Wireless 7260
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:3c:00.0
version: c3
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: memory:9a400000-9a401fff
~$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Last time i did rfkill list the wireless showed up and was also not soft blocked or hard blocked
You said you are dual booting with Windows, so a couple things come to mind.
(1) Disable Secure Boot in the BIOS
(2) Disable Fast Startup in Windows.
Windows is like a virus in of itself these days, it likes to retain control, which is what a virus does BTW. Unless you absolutely need Windows for work, or playing Anti-Cheat multiplayer games, I highly suggest running Linux only.
Hmm .. there is at least the Wireless Controller detected ... do you have in Your BIOS a Setting for enable/disable the Wifi controller? Please check that.
And are You on Zorin 17 or 18?
I disabled secure boot, and fast startup already. I am on zorin 18
