Wine problem
Is wine-stable installed defaultly in zorin os? Bc i now have wine-staging. How to get back the regular wine bc desktop files directing to wine apps dont work anymore.
Wine isn't installed by default. But You should have a Shortcut. When You click on it, it brings You in the Gnome Software Store where you can install it.
Zorin has their "Windows App Support" in Software Store that includes Wine and Play-on-Linux. You can simply find and install that.
It worked, it was ok after i reinstalled the apps but i just reinstalled Zorin OS for other reason
