Hello. I am looking for a wine theme similar to zorin os. If you have any good themes, I would love to hear about them.
Also, I know how to install the theme, but I don't know how to uninstall it (remove it from the list). How can I uninstall it?
Thank you in advance.
In your home directory there is a .themes folder you should be able to just remove any you installed from there. You may have to enable show hidden items
Thanks to you I have solved the problem! Thank you very much!
