Would appreciate advice buying a laptop to install Zorin
Hi - I'm in NZ and bought it off Trademe, our ebay. Ebay should be fine for you. Look for excellent feedback.
I installed the linux.
I have several Fujitsu Lifebooks (A-, E- and S-Series of different ages (4-8 years) running Zorin 17.3 or Kubuntu 25.10 without any problems
My X1 was "gifted" to me by my employer when I retired. It was a much better retirement gift than a watch! I immediately installed Zorin and deleted Windows and all of the associated bloatware, freeing up tons of space and speeding up the laptop.
You might also want to look at Amazon Renewed for refurbished laptops and desktops. I just bought an older refurbished Lenovo ThinkCentre M910Q mini desktop computer with an Intel i7 processor, 32gb RAM and a 1Tb SSD for $319. (It's since gone up to $379) and installed Zorin on it. It probably wouldn't work well for serious gaming or video production, but it's perfect for my home PC needs.
Hi all. I'm still researching (the lappie). I've looked at the Certified laptops Unbuntu site. Decision is still btw Dell, Lenovo & HP. WRT HP, there's plenty of 2h Elitebooks & Probooks to choose from. I've seen some comments about HP (apart from hinge problems) & issues with drivers and Linux compatibility. Issues can happen with any device. I wonder if anyone has things to say about their experience with HP laptops & Linux, to help me decide, yes or don't do it.
Not a notebook, but an all-in-one HP. Avoid at all costs. A member based in Arizona bought two when they were brand new. The member could not remember the HP BIOS password set at the factory and because it is out of warranty HP advised to buy a new one! I would avoid HP like the plague. I would also avoid Toshiba.
From personal experience I would stick with Dell as they were the first mainstream manufacturer to ship with GNU/Linux (Ubuntu).
Just before lockdown work gifted me a Dell Latitude E5500 that originally had come with Vista on it so could not be upgraded to Windows 10. I upgraded it from 2 Gb to the max of 8 Gb RAM, replaced the failing CMOS battery, and repaced the DVD/CD-RW with an 8x DVD/RW. I also swapped the 170 Gb HDD for a Crucial M.2 SATA drive of 1 Tb. I was hoping to put Zorin Education on it for my eldest who was a Teaching Assistant, but it kept freezing and crashing, so I put MX-Linux 23.1 KDE Plasma on it and installed all the relevant Education software using Synaptic Package Manager. Short-lived as eldest's Windows 11 drive (HDD) was failing so it (the SSD) got moved to the tower for Windows 11. The original hard drive went back in with MX-Linux 23.1 KDE Plasma.
The other recommendations are Ideapads and Thinkpads but I have never used one. There were some issues after IBM sold the Brand to Lenovo, but as I understand it, they do work well with GNU/Linux.
In respect of Acer, these can run GNU/Linux. I personally witnessed a student client years ago having issues with an Acer. Their sibling hadcthe same HDD problem as themselves, the sibling got a replacement but they did not and it was in Warranty.
One thing that is crucial is that you ensure that any notebook you purchase does not use a membrane keyboard (like Asus), and preferably a matte screen, unless you are narcissistic! I would also look at one with Backlit keyboard.
I withdraw my Lenovo recommendation:
Sound issues.
It's not an issue with Lenovo, it's the Nvidia graphic card which caused the audio issue or perhaps Zorin / Ubuntu not mapping out the correct Nvidia configuration. Now that I have found the solution all works fine.
thanks for info, glossy screens give me eye strain and headaches
I have 3 HP all on Linux with out any problems and I am not technical. All are old, 1 9 ys. Avoid Nvidia graphics, AMD is good. Watch a good installation video and do not use Balena Etcher (bad, bad, bad), use Ventoy.
Sorry I don't agree with your opinion about Toshiba. I have older Toshiba Satellite 2014 laptop and all working correct. Here is important graphic card to isn't Nvidia. Better option is to have AMD graphic card.
Yes, Lenovo used to be well regarded. It no longer is.
I would buy Any Brand before Lenovo...
Dell + Linux = Yay
that is what I use.
I forget how old I am and it was based from many years ago. I do remember a different story about GNU/Linux and Toshiba, also years ago. Ab Australian took Toshiba to court because rhey would not provide him a notebook without ant OS installed, and he won. There have been issues in the past where some key components would not work.
I remember playing around with an old Toshiba Satellite Pro that work were disposing of, tge real early ones that weighed about 5 lbs. It would not boot from CD so had to use Plop! Boot to do so and because of it's low spec I had to use Wolvix Cub and was able to drill down into the graphics commands to get the screen working. Wolvix was a great distro.
I have installed it on an old Toshiba laptop and currently installed it on a DELL 5480 laptop. The install was easy and i have had no issues.
As a suggestion, you can buy a 4 year old laptop or desktop and try Zorin on it. It will be cheap. If you are going to play STEAM PC games on it i would suggest getting a reasonably large SSD disk, at least 512GB if not larger. If you are going to use it for word processing then i would get a NAS and use that as your on-line storage if you can't get enough disk storage.
Hi and welcome. I don't think a NAS is a solution for storing data such as Text Processor files. NAS is used from what I have seen posted here, for streaming stored music and movies. Just use an external portable drive unless you zcan get your hands on a notebook that can take 2 drives, 1 SSD for the OS and 1 HDD for data as continual writing to SSD will shorten the life of SSD.
