Yabridge seems not working on Zorin 17
Hello,
I want to use vst3 plugin with Yabridge on Zorin 17 but it seems it doesn't work. Has anyone been able to make it work?
I've tried with Ubuntu 22.04 and it works. I use Reaper and Ardour to test.
Thanks for your help
Have you double checked install and status?
Thanks for your help.
It's work now with Reaper but not with Ardour. It's a little bit slow so I will try to find another solution.
Any help here?
https://www.reddit.com/r/linuxaudio/comments/vy7gf3/yabridge_reaperardour_hangs_on_vst2/
Also:
https://linuxmusicians.com/viewtopic.php?t=24832
Might be worth postoing to linuxmusicians? Explain you are running a fork of Ubuntu 22.04
