00:00.0 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.1 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.2 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.3 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.4 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:00.7 Host bridge: VIA Technologies, Inc. K8M800 Host Bridge
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/8251 PCI bridge [K8M890/K8T800/K8T890 South]
00:09.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
00:0f.0 RAID bus controller: VIA Technologies, Inc. VIA VT6420 SATA RAID Controller (rev 80)
00:0f.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:10.0 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.1 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.2 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.3 USB controller: VIA Technologies, Inc. VT82xx/62xx UHCI USB 1.1 Controller (rev 81)
00:10.4 USB controller: VIA Technologies, Inc. USB 2.0 (rev 86)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8237 ISA bridge [KT600/K8T800/K8T890 South]
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 60)
00:12.0 Ethernet controller: VIA Technologies, Inc. VT6102/VT6103 [Rhine-II] (rev 78)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:00.0 VGA compatible controller: VIA Technologies, Inc. K8M800/K8N800/K8N800A [S3 UniChrome Pro] (rev 01)
Let's deal with sound first. Open a terminal (Ctrl+ Alt+ T) and enter:
sudo nano /proc/asound/modules
and paste back the results here.
Is it happening only on youtube?
unable to play video from CDs too.
ok. i will do. thanks for responding
GNU nano 4.8 /proc/asound/modules
[ Error writing lock file /proc/asound/.modules.swp: No such file or directory ]
^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
^X Exit ^R Read File ^\ Replace ^U Paste Text^T To Spell ^_ Go To Line
hmmn.... what is the solution ??
First line = you don't have the rights to write that file. (
[ Error writing lock file /proc/asound/.modules.swp: No such file or directory ])
Next two lines are reference to Help choices...
Maybe @Aravisian or @337harvey may know more.
You mentioned that you can't play videos from CD either but that can be a completely unrelated problem. And what do you mean by "Youtube video playing very slow"? Is it buffering? In that case, it might be an internet issue? Did you check in any other websites?
About the sound issue...Can you not hear anything? or is it just in Youtube? Lastly, try using any other browser to check if the problem exists there as well....Also, is the CD getting detected at all or you can see the video files but can't open them?
You do not have that file.
On your videos:
You may just need the Codecs:
Take a look at this thread:
