I just installed Zorin OS 16 Core on my desktop. I have it on my notebook and bluetooth works seamlessly. However, on the pc, every time I try to turn it on... it doesn't. It doesn't turn on, whatever I do.
Mind you, I am an absolute beginner and don't know much (if anything) about tech. I've tried many "solutions", to no avail.
Please, please help. I need bluetooth for work and college and this is reeealy throwing me off from using the OS.
This was lsusb's ouput:
Bus 001 Device 006: ID 0bda:8771 Realtek Semiconductor Corp. Bluetooth Radio
Weird thing is, this dongle worked on fedora out of the box.
I ran these commands. This was the output. I'll translate, as my terminal runs on my mother language.
nick@nickzodia:~/.driverLinux$ make
make: *** No target indicated and no make file found. Stop.
nick@nickzodia:~/.driverLinux$ sudo make install INTERFACE=all
[sudo] senha para nick:
make: *** No rule to process target 'install'. Stop.
I had actually extracted it to my home folder and renamed it to driverLinux. I extracted it to Downloads this time, didn't rename, did exactly as you described. Same outputs
I did. The command itself worked, the terminal found the make file and installed it. It's just that towards the last lines there were errors (and now the pc doesn't recognize that there's a dongle plugged in, for some reason)
I will, but I might try a new OS. Zorin serves me perfectly well on my notebook, I recommend it to everyone I know and I'll keep being a user, but for someone as technologically inapt as me, doing a lot of probing gets difficult. I also can't get the speakers to work, for some reason. I'll look a llittle further into distros, although I really love Zorin.
Update: bluetooth is working after unpluggling the dongle, restarting the pc, running "sudo make install INTERFACE=all" and plugging the dongle back in. I'm still working on the speakers though. On this part it seems to be a audio outputs issue. I'll hork harder on it and, let it be fixed, keep Zorin as my desktop OS.
I'll also keep an eye on the bluetooth, as it won't necessarily remain working, although working now. I'd say for now the issue is closed! Tysm for your patience and help.
I think we can all make this statement. Yet, here we accept our challenges. Maybe we are not as inept as we think we are. You can plainly see in this thread I am no guru and was flying by the seat of my pants with guesswork.
When I used Windows, I was often net-searching how to fix something. It does not matter really, which OS you use, there will always be a moment to fix something in a way new and unfamiliar.
Hey... We landed people on the Moon.
We can do anything.
