I can do better then tell you, I can show you.
In the deep dark void of endless expanse, as long as I have thy popcorn, everything will be ok. StarTreker 2021
There is a Warning to remove the PPA in this link I posted elsewhere re Popsicle: Popsicle - Create Multiple Bootable USB Drives At Once - OSTechNix
"Once installed Popsicle, remove the PPA. Because, it will keep asking you to upgrade to the next available Pop!_OS version."
I'll take note of these bootable things. I use balena or just right click tada! hahahahah
Paragon Linux is more simple to creating a backup OS.
