MrStan
August 20, 2021, 7:46pm
25
stan@stan-Gaming3-15ACH6:~$ inxi -nx
Command 'inxi' not found, but can be installed with:
sudo apt install inxi
stan@stan-Gaming3-15ACH6:~$ sudo apt install inxi
[sudo] password for stan:
Reading package lists... Done
Building dependency tree
Network:
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: 7c:8a:e1:8c:16:84
Device-2: Realtek vendor: Lenovo driver: N/A port: 2000 bus ID: 03:00.0
Grumble... gripe....
MrStan
August 20, 2021, 7:50pm
27
yep... wired internet works fine
Yeah....
In terminal, can you try:
sudo apt install r8168-dkms
MrStan
August 20, 2021, 7:55pm
29
stan@stan-Gaming3-15ACH6:~$ sudo apt install r8168-dkms
dctrl-tools dkms
Suggested packages:
debtags menu
dctrl-tools dkms r8168-dkms
0 upgraded, 3 newly installed, 0 to remove and 4 not upgraded.
afterwards I tried this again:
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
MrStan
August 20, 2021, 7:57pm
30
I did this:
sudo apt upgrade
but the results from inxi -nx were unchanged
Can you please reboot and test again?
MrStan
August 20, 2021, 8:04pm
32
Just did just reboot again... same results from inxi -nx
Ok but your wireless? No good?
Can you run
rfkill unblock all
rfkill list all
and post the results here?
MrStan
August 20, 2021, 8:06pm
34
Should I try running LIVE versions of other recent distros to see what they do? If so, what terminal commands would you like me to record?
MrStan
August 20, 2021, 8:07pm
36
stan@stan-Gaming3-15ACH6:~$ rfkill unblock all
stan@stan-Gaming3-15ACH6:~$ rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
2: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
MrStan
August 20, 2021, 8:08pm
37
Zorin is installed alongside windows, so I can provide details from that OS if you desire
Secure boot is disabled, right? IF unsure run:
sudo apt-get install mokutil && mokutil --sb-state
Otherwise:
Wanting to punch me yet?
sudo apt-get install git build-essential linux-headers-$(uname -r)
git clone GitHub - lwfinger/rtw88: A backport of the Realtek Wifi 5 drivers from the wireless-next repo.
cd rtw88
make
sudo make install
Remove the junk left over:
rm -v -R --interactive=never ~/rtw88
sudo reboot
...and test. Sorry about all this rebooting... at least your RAM is getting a cleaning.
MrStan
August 20, 2021, 8:14pm
39
secure boot is enabled. I entered a password to setup zorin. Should disable it?
MrStan
August 20, 2021, 8:15pm
40
stan@stan-Gaming3-15ACH6:~$ sudo apt-get install mokutil && mokutil --sb-state
mokutil is already the newest version (0.3.0+1538710437.fb6250f-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
SecureBoot enabled
Secure boot must be disabled for this to work...
MrStan
August 20, 2021, 8:18pm
42
just return from reboot... okay, disabling secure boot... one sec
MrStan
August 20, 2021, 8:21pm
43
stan@stan-Gaming3-15ACH6:~$ iwconfig
lo no wireless extensions.
enp2s0 no wireless extensions.
wlo1 IEEE 802.11 ESSID:"Reflection"
Mode:Managed Frequency:2.427 GHz Access Point: 14:91:82:86:11:ED
Bit Rate=144.4 Mb/s Tx-Power=30 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Link Quality=70/70 Signal level=-23 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:48 Missed beacon:0
\o/
MrStan
August 20, 2021, 8:23pm
44
so it was something basic that I needed to do.
should I leave 'Secure Boot' off or can I turn it back on now that we have wifi in zorin ?
