Ok I understand. hopefully I will be able to run the procedure by the weekend. I thank you all for your assistance and will post the outcome one way or another.
Hi to you all. Following your much appreciated help I am now able to go on-line without depending on a dongle. I had no issues with following your procedure and hopefully it will assist anyone else with a similar problem. Thanks again.
Glad to hear that the WiFi is working for you
Now you also have a USB dongle which is known to work with all modern Linux kernels
This will make your life easy in case you have to make re-installation or new installation on another computers.
Please select the posting which solved your issue and mark the thread as solved
This will help the future visitors to this forum.
