Zorin 17 Not Recognising my MOnitor or my 1660 Ti
I have connected my MOnitor to my laptop and Zorin refuses to indentify it aswell as it refuses to use my 1660 TI as the main GPU or even recognise it as a secondary one
I see you are log in in Wayland so you have first to log in XOrg before using the nvidia card.
To switch between the cards
sudo prime-select nvidia
back again:
sudo prime-select intel
Wayland working good on some distributions linux. Wayland is alpha to 2026.
Wayland i tested it not gived in some application my primary language.
Wayland long way to working properly.
