Hello Ladies and Gentlemen,
Some or maybe all of You might detected the Updates of the last Days and that there were a certain Amount of Zorin one's. And it seems that this lead to the .1 Point Release of Zorin 18:
Has anything changed or improved in the 1.0 release of Zorin 18?
Has anyone noticed anything yet?
There came Updates for LibreOffice and for the Zorin Gnome Extensions.
Yeah, just keep a close eye @Ponce-De-Leon on it, something tells me that the point release is not going to fix the major issues that people have been reporting, and will only fix the minor ones, involving those Gnome extensions. No news about the release either, it just popped up out of nowhere. Like I always say, will see.
I'm now also on the .1 point release of Zorin 18
So far, I haven't noticed any changes or improvements.
But it seems to be running without any issues
After these days of 18.1 updates, everything is normal except the Nautilus folder-color extension is lost. I don't know if it was intentional, or some bug in the installation of the updated packages (could it be some Nautilus update?).
sudo apt install folder-color restores it directly from the Zorin repositories without major problems.
It is intentional as it was found that folder-color was causing file manager crashes.
I would LOVE if this would coincide with a Lite release.
Agreed.
I think this is preperation for Ubuntu 26.04 LTS, I'd expect a full .iso release by April 30th-May 7th, especially with kernel 7 showing stability.
I wish they would have updated the linux-firmware from 2024 as there are major show stopper bugs with 6.17 and the amdgpu firmware for the 8xxxg series apus.
I had to pull the latest firmware from github for the admgpu just to get the login screen in 6.17
I' advising you to remove it because the version still have some memory leak and may crash again nautilus, I made a corrected version (folder-color-revival) you can find here :
No, it isn't. Zorin 18 is based on Ubuntu 24.04 and it will be. The Base will change with Zorin 19.
and it will be in more than 1 year if they follow their update plan
No. It is not.
i said i think it was
you can dream, it's your right...
What kinda dreams? Lucid dreams?
