Zorin Connect works but, recently switched to using Proton VPN on my phone (previously used DuckDuckGo VPN). With Proton VPN I have no connection where as I had a connection DuckDuckGo.
I take it have to delete the original connection and pair it again with Proton VPN running?
The reason I'm asking is I don't want to create any more problems for my self by destroying the connection I have. Push comes to shove I'll just knock off Proton VPN to do a file transfer.
Any advice would appreciated.
Thanks Dai
I was surprised to learn that you were able to connect with DuckDuckGo VPN.
Proton VPN creates a fake IP address so I suspect that because of this it obviously can't connect to the same network. I don't know if the paid for version offers a workaround. I have to turn Proton VPN off when connecting to my PCLOS Debian Plasma when using KDE Connect.
Just done a search using Brave A.I. via Mojeek search engine in respect of KDE Connect, but suspect the tunnel-splitting may only be available in paid version, will need to check.
" To allow KDE Connect to work while your smartphone uses ProtonVPN, the most effective solution is to configure split tunneling or LAN exceptions within the ProtonVPN mobile app.
1. Enable Split Tunneling or LAN Exceptions on Android
- Open the ProtonVPN mobile app settings.
- Locate the option for "Split Tunneling" or "Allow LAN connections" (sometimes labeled as allowing specific apps to bypass the VPN).
- Add KDE Connect to the list of allowed apps, or enable the general LAN exception.
- Restart the ProtonVPN connection or your phone if the devices do not immediately reconnect.
2. Alternative: Connect Both Devices to the Same VPN
- If split tunneling is unavailable or insecure, connect your PC to the same ProtonVPN server as your phone.
- Note that this routes all KDE Connect traffic through the VPN tunnel, which may reduce performance and latency compared to local network communication.
3. Firewall and Network Configuration
- Ensure your PC's firewall allows KDE Connect traffic on the local network zone.
- If using a custom OpenVPN setup, you may need to whitelist the local network subnet (e.g.,
192.168.1.x) in the VPN client settings to prevent the VPN from isolating local devices.
Yep, split-tunneling is only available in the paid version of ProtonVPN. As you are only accessing the local network, no need for VPN while using apps for file transfers etc.
That's what I'm doing at the moment. will look into the split Tunneling.
Thanks
Just remember split-tunneling is not available on the free version of ProtonVPN - you have to take out the subscription model to be able to use it.
