Zorin Connect doesn't work the same as KdeConnect. It doesn't let me transfer multiple selected files to my phone. I have to transfer them one at a time; it's tedious. This app is very important to me because I work with images every day. Is there any way to fix this issue?
IS KDE connect from the flatpak repositories? It may be newer than Zorin connect.
If KDE connect works for You, You could simply use that.
kdeconnect on my mobile. Zorinconnect on Zorin.
I want to use Zorin OS with Zorin Connect and KDE Connect on my phone.
Unless I'm mistaken, but if one uses KDE Connect on their phone, they must also use KDE Connect on their computer? I'm fairly certain thats how it works.
BTW, do you not have the option to just plug the phone into the computer via USB? I certainly have that option, and transfer speeds are far faster on wire, vs wireless.
I don't think that this is intended to work. I would suggest to take the same Program on both Devices.
Thank you. The idea is to avoid using cables; it's more practical and versatile to use Wi-Fi over a LAN.
OK thanks
My apologies to everyone. I thought Zorin Connect worked with KDEconnect. I didn't know Zorin Connect had an app on the Playstore. Issue resolved. Thanks again, and sorry.
Moved to General Help as was not related to Customisation subject matter.
Also marked @StarTreker 's post #6 as OP has stated "Issue resolved", using KDE Connect both ends.
