doobre
October 12, 2025, 11:12pm
21
Hi there, thanks for the reply, BUT
I have only recently purchased the 'Pro' version of 17.
It should be able to do all the tasks that I require of it already, without the need to recompile/upgrade.
It seems that I have encountered a flaw in the OS and I request to be refunded or provided v18 'Pro' in it's place.
Which should be able to utilise the HW without a further problem.
cheers CD
Your profile states Core not Pro.
doobre
October 13, 2025, 6:32am
23
Hi there
Yep, first I used 'core' for free, then bought the Pro on Oct 4th. Cos I was liking what a found and you people are so helpful and patient.
cheers CD
doobre
October 13, 2025, 6:39am
24
Actually, where does that show up in my profile? editable?
edit - Found it, done
system
Closed
January 11, 2026, 6:40am
25
