Zorin Icon seems to have shrunk a tiny bit after updating on 04/03/2026
Is it just my imagination or did the Zorin Icon on the task bar shink an itty bitty bit? Hardly noticable but noticable if that makes sense! :laughing:
It looks smaller, yes. There came an Update for the Zorin Startmenu. Did You already made a Reboot?
EDIT: I got a new Zorin Menu Update to Version 5.3.2. See if it is availabe for You and install it. Maybe it helps to correct that.
Yes, I just checked and there was an update for the Zorin Menu... I installed it logged out and back in and the Zorin Icon is now fixed! Thank You!
