Since I reinstalled zorin 15.3 lite. My PC is not remembering my display brightness. I always set my brightness level to 100% but after every restart it goes back.
Any ideas on where should I look?
I'm not sure; I would think /sys/class/backlight/ configuration, not GPU.
But you might try the steps in this guide to solve your issue:
Thanks for reply, The article you mentioned is vice versa to mine. My PC gets dimmed after a restart and I want to keep it always at a maximum level whereas the article provides solution for Brightness is reset to maximum on every restart but after reading it seems like the solution is same for both.
In the article they said to add line to to /etc/rc.local but I can't find such file named rc.local in etc
That guide may be outdated. Let me look into it further.
Maybe try this ? Amd/ati card (if you have a different gpu please let us know and you can skip this post)
To find current brightness level:
cat /sys/class/backlight/amdgpu_bl0/brightness
Set the brightness on boot using:
echo 30 > /sys/class/backlight/amdgpu_bl0/brightness
I'm sorry for being dumb, How can I find what gpu I have?
sudo lshw -c video
*-display:0
product: Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 03
width: 32 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:16 memory:ee100000-ee17ffff ioport:1800(size=8) memory:d0000000-dfffffff memory:ee200000-ee23ffff memory:c0000-dffff
*-display:1 UNCLAIMED
description: Display controller
product: Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller
physical id: 2.1
bus info: pci@0000:00:02.1
version: 03
width: 32 bits
clock: 33MHz
capabilities: pm cap_list
configuration: latency=0
resources: memory:ee180000-ee1fffff
There you have it.
Yes, that is for AMD only.
What is the output of ls /sys/class/backlight/
. Is it acpi_video0
or is it something that begins with intel or something else.
Yes it is acpi_video0.
Okay, try the following.
Open /sys/class/backlight/acpi_video0/max_brightness
. You will see your max brightness value there. Now go to terminal and run ~/.maxbrightness.sh
. In your OP, you said that you want to set your brightness to 100%, so in the the text file, paste the following and change 'x' with the value you saw when you opened the file max_brighness.
#!/bin/sh
#change brightness setting to 50 percent on startup or resume
pkexec /usr/lib/gnome-settings-daemon/gsd-backlight-helper --set-brightness x
Save it and then run chmod +x ~/.maxbrightness.sh
. Again in terminal run
gsettings set org.gnome.settings-daemon.peripherals.input-devices hotplug-command "/home/USERNAME/.maxbrightness.sh"
Replace USERNAME with your username in the above command.
Try logging out and the logging in. Let's see if it works.
Thanks a lot. Unfortunately I can't follow the steps because I posted the same question in zorin's reddit page which I haven't done before. Two people there said to tryout Zorin 16 despite having a low end machine which made my mind change quickly and without a second thought I installed Zorin 16 and the brightness issue is not there but I will mark this post as solution as it might help others.
Thank you.
