Zorin OS 17.3 Pro
The PRO licence can be for a family. one IP. or is it just for ONE computer?
One household. So if you at home has 3 PCs you can install them on 3 PCs.
But you only get support for one machine, the first you install it on. If you have an issue with one of the machines in live mode, choose that as your primary computer to install to, and if the others have no issues, install to those, should you need technical support from Team Zorin, make sure that you install Zorin Pro on the one that has issues in live mode first.
