Zorin OS 17 Core - ClamAV and ClamTK - Installed and working effectively
Seems normal enough. Sometimes packages are held back and may be due to some dependencies issues. Nothing to worried about.
You could make a sudo apt autoremove to clean the named Files and then try to install clamav and clamtk again with the command sudo apt install clamav clamtk
But I have one question: What did You want to do with this touch Command and the freshclam.log File?
Thanks for your response. Executed the code:
sudo apt install clamav clamav-daemon
Result:
uy@guy-Aspire-A515-52:~$ sudo apt install clamav clamav-daemon
[sudo] password for guy:
Reading package lists... Done
clamav is already the newest version (0.103.11+dfsg-0ubuntu0.22.04.1).
clamav-daemon is already the newest version (0.103.11+dfsg-0ubuntu0.22.04.1).
libcommon-sense-perl libjson-perl libjson-xs-perl libtext-csv-perl
libtext-csv-xs-perl libtypes-serialiser-perl libwmf0.2-7-gtk
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
guy@guy-Aspire-A515-52:~$
Will execute code:
sudo apt install clamtk
Please advise.
Executed code:
Result:
guy@guy-Aspire-A515-52:~$ sudo apt install clamtk
The following package was automatically installed and is no longer required:
libwmf0.2-7-gtk
Use 'sudo apt autoremove' to remove it.
Suggested packages:
clamtk-gnome
clamtk
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 185 kB of archives.
After this operation, 989 kB of additional disk space will be used.
Get:1 Index of /ubuntu/ jammy/universe amd64 clamtk all 6.07-1 [185 kB]
Fetched 185 kB in 5s (37.3 kB/s)
Selecting previously unselected package clamtk.
(Reading database ... 272405 files and directories currently installed.)
Preparing to unpack .../archives/clamtk_6.07-1_all.deb ...
Unpacking clamtk (6.07-1) ...
Setting up clamtk (6.07-1) ...
Processing triggers for desktop-file-utils (0.26-1ubuntu3) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu3) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for mailcap (3.70+nmu1ubuntu1) ...
Please advise.
Did you made the sudo apt autoremove before the Install?
Executed the codes:
uy@guy-Aspire-A515-52:~$ sudo systemctl stop clamav-freshclam
guy@guy-Aspire-A515-52:~$ sudo freshclam
Thu Feb 1 21:26:15 2024 -> ClamAV update process started at Thu Feb 1 21:26:15 2024
Thu Feb 1 21:26:15 2024 -> daily.cvd database is up-to-date (version: 27172, sigs: 2052033, f-level: 90, builder: raynman)
Thu Feb 1 21:26:15 2024 -> main.cvd database is up-to-date (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
Thu Feb 1 21:26:15 2024 -> bytecode.cvd database is up-to-date (version: 334, sigs: 91, f-level: 90, builder: anvilleg)
Results read that the ClamAV database is updated.
Please advise further. How do I know if the signatures are updated?
That stand in Your Output:
And You can use clamtk. This is the graphical Interface so you don't need to use the Terminal. Look:
Thank you very much for your support. It is greatly appreciated.
Found the following instruction very helpful:
Please lets continue our engagement when we learn something new about ClamAV.
Regards
Guy
Thank you for your support. We have taken this exercise one by "Storm".
Regards
Guy
