Zorin os 18C crashing when using electron apps
FW16/7840HS/5070
Anyone having this issue? I’ve disabled gpu acceleration for all these apps but they still crash
MY SYSTEM:
Hardware: Framework Laptop 16, RTX 5070 Laptop GPU (GB206M), AMD Ryzen 7840HS
BIOS: 04.03
OS: Zorin OS 18
Kernel: 6.17.0-20-generic
NVIDIA Driver: 580.126.09 (Open Kernel Module)
Display: PRIME setup — AMD iGPU handles display, NVIDIA handles rendering
Session: X11/GDM
ERROR LOGS:
BRAVE:
Apr 04 23:25:33 brave-browser.desktop[5521]: SharedContextState context lost via EXT_robustness. Reset status = GL_GUILTY_CONTEXT_RESET_KHR
Apr 04 23:25:33 brave-browser.desktop[5521]: Restarting GPU process due to unrecoverable error. Context was lost.
Apr 04 23:25:33 brave-browser.desktop[5521]: GPU process exited unexpectedly: exit_code=8704
Apr 04 23:25:33 gnome-shell[2632]: Running GNOME Shell (using mutter 46.2) as a X11 window and compositing manager
Apr 04 23:25:33 /usr/libexec/gdm-x-session[2332]: (--) NVIDIA(GPU-0): DFP-0: disconnected
CLAUDE:
Apr 05 14:56:24 kernel: traps: electron[6091] trap int3 ip:5a81044d38a5 sp:7ffce2238c90 error:0 in electron[6ed78a5,5a80ffc8b000+9703000]
Apr 05 14:56:24 claude-desktop.desktop[6081]: /usr/bin/claude-desktop: line 75: 6091 Trace/breakpoint trap "$electron_exec" "${electron_args[@]}" "$@" >> "$log_file" 2>&1
Apr 05 14:56:24 com.discordapp.Discord.desktop[5198]: [53:0405/145624.098511:ERROR:ui/gfx/x/connection.cc:65] X connection error received.
CLAUDE + BRAVE:
Apr 08 22:49:06 kernel: traps: electron[8949] trap int3 ip:55650a21a8a5 sp:7ffeca12b430 error:0 in electron[6ed78a5,5565059d2000+9703000]
Apr 08 22:49:06 claude-desktop.desktop[8939]: /usr/bin/claude-desktop: line 75: 8949 Trace/breakpoint trap "$electron_exec" "${electron_args[@]}" --disable-gpu "$@" >> "$log_file" 2>&1
Apr 08 22:49:06 com.discordapp.Discord.desktop[5580]: Trace/breakpoint trap
Apr 08 22:49:06 com.discordapp.Discord.desktop[5583]: [FATAL:electron/shell/browser/electron_browser_main_parts.cc:501] Failed to shutdown.
ACPI FIRMWARE:
ACPI: thermal: [Firmware Bug]: Invalid critical threshold (-274000)
ACPI: thermal: [Firmware Bug]: No valid trip points!
ACPI: video: [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
ucsi_acpi USBC000:00: unknown error 256
ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
So, it is the 580 open Driver, yes? You could try the non-open Version or go higher an use the 590 Driver.
Another Thing ... I have Doubts that it would solve it but it should be worth a Try. Switch to Wayland and check if it behaves different. To di that, go to the Login Screen. Click there on Your Profile so that the Password Field appears. When it is appeared, You should see a Gear Icon in the bottom right Corner. Click on it.
Now it depends if You have installed Zorin with Nvidia Drivers or without. When with Nvidia Drivers choose the Option ''Zorin Desktop on Wayland'' and then log in.
When You have installed Zorin without Nvidia Drivers choose the Option ''Zorin Desktop'' and then log in.
