https://www.reddit.com/r/zorinos/comments/1rulu0i/comment/oanf0y1/?context=1 (this is the original reddit thread i posted and they referred me here, the video is also on here if you need it)
ryzen 9 5900x
RTX 3050
165hz monitor
ryzen 9 5900x
RTX 3050
165hz monitor
What are you trying to do? It looks normal to me. You drag your window onto one of the blue layouts at the top of the screen, and then it gets placed there. Is something wrong?
You can disable the advanced window tiling function at Zorin appearance if you don't like it.
For more window animations you can e.g. install the gnome extension "Burn my windows"
Maybe some animations don't work together with the Zorin tiling shell gnome extension, so it can help to disable the Zorin tiling shell for testing.
What Animations do You expect to get? I mean: How do You think should it look like? Or are You annoyed from the white Tiling Fields? You can disable that like @Forpli already wrote.
no there use to be animations and stuff, no they just appear without any fading. I fixed this issue a while back now
Click
icon bottom of screen, click system tools.
Scroll, click on Appearance.
I also have Burn My Windows extension, oh what flaming transitions!
