Is this even possible?when I move folders I have to 'ctrl+r' to refresh(Reload) to confirm the move; or when observing storage amount changes in realtime. Is there an auto refresh command with and interval of one second?
Are you referring to Nautilus File manager? (Zorin OS Core)
If you meant refreshing Nautilus, I think you can do it from terminal:
nautilus -q
or killall nautilus
ZORIN OS lite
If that is the case:
thunar -q
Then reopen the file manager (Thunar)
This sounds like a bug. My Thunar does not behave that way.
Doing a Net Search, I found some older bug reports for Thunar that mentioned the exact thing you describe.
Can you try:
sudo apt install --reinstall zorin-os-desktop-lite
Ah, now I understand what the problem was.
I have Zorin Lite on laptop but I do not use it that often and was not aware of this bug.
Package unable to be located
Hmm... I just looked it up... I make mistakes, sometimes
sudo apt install --reinstall zorin-os-lite-desktop
It's good to know you are human;Amazon is looking to phase us out
Best post of the week.
