Zorin OS Lite randomly freezing
So my zorin os lite randomly freezes for 20-30 seconds in which mouse and keyboard dont work
Its like the display became static
I use chrome.(Is it the issue?)
go on to software search additional drivers install it
and see if theres display drivers that need to be installed
No additional drivers
Gday @Bani1234 ,
Can you let us know your machine spec's please.
Brand/Model:
CPU:
Ram:
Graphic's:
HDD/SSD Capacity:
Also are you dual booting?
How long have you had this setup?
Has this been happening since Installation or just recently?
Does it only happen when using Chrome?
This especially. You can grab that info with
sudo lshw -C video
