Zorin OS on an external drive
Hi. Is it possible to install Zorin OS Pro on this disk device:
Thanks.
It should be possible however,
I'd advise you to look for an SSD, that appears to be a HDD
You'd experience much slower times and speeds of use/read and write on an HDD.
Theoretically, You can do it. Do You want to have the Possibility to have the OS mobile? Or don't You have a 2nd internal Drive?
