Zorin OS Pro on Dell Inspiron 7700 AIO
I bought Zorin OS Pro a few days ago and Installed it, dual-boot with Windows 11 Pro, on my Dell All -in-one PC [Inspiron 7700AIO, 11th Generation i7, 16GB]. The install took forever, 5 or 6 times as long as installing Windows 11.
Once installed the system is very slow, with a curious dead period after booting in which nothing will start - possible 4 to 5 minutes. I'm also seeing lots of messages telling me that this or that program will not work and do I want to force shutdown or wait.
Once up and stabilised it is still painfully slow compared to the same machine in Windows 11 Pro.
I've searched for help and found various tips - like changing the graphics system to korg, which produced a distinct improvement but still nowhere near the performance of the same machine in Windows.
I have loaded Linux mint on this machine in the recent past, and it was super snappy in performance. Compared to it, Zorin OS 18 is a joke.
The publicity for Zorin OS and a couple of reviews I've seen speak of it as a worthy substitue for Windows and, since it is a serious commercial entity, I'm sure that users must be obtaining a competitive level of performance.
What have I done wrong?
Ed Form
You haven't done anything wrong, but I always advise users to try the Core version first before purchasing the Pro version
As you have purchased Pro you are entitled to support from Team Zorin so I would contact them via this form to assist with your issues:
Maybe nothing. We could check some Points:
  • Could You post Your Hradware Specs? I mean, You already posted the CPU and RAM, but what is with GPU? And do You use a HDD.SSD or an m.2?
  • Is Fast Start-Up in Windows disabled?
  • Is Your BIOS in UEFI or Legacy Mode?
  • What tool did You use to create the Bootstick?
  • What Installation Option did You choose? ''Install Zorin alongside Windows'' or ''Something lese''?
  • Did You checked the Checksum of the ISO?
  • Did You tried Zorin OS in Live Mode (from the USB Stick) before You have installed it? If yes: Did it run normally?
An update on my issues - My hardware is a Dell Inspiron 7700 AIO, a 27 inch monitor with a Generation 11 i7, 16GB of RAM, A 500GB system SSD, a 2TB spinning disk for data, an iscsi external disk - its actually a 6TB QNAP Nas, and the i7's on-chip graphics.
BIOS is UEFI, and is undisturbed from the way Dell delivered it, so it will be optimised for Windows 11.
I wrote the Bootstick with Balena Etcher.
I installed Zorin alongside Windows 11.
I allowed the installation routine to run all the Checksums at the beginning of the install - I did not look at the Checksum of the original ISO.
I did not try Zorin from the stick.
My original complaint was that the OS was ponderous, unresponsive for a couple of minutes at each boot, and slow to respond thereafter compared to Windows 11.
Now the good bit - I grew sick of the way it acted, so I threw caution to the wind and installed it as the only OS. It is now snappy, faster to respond than Windows 11, and I intend to stick with it.
I had tried several Linux Distros in the past, most recently, and distinctly most positively, Linux Mint, but I returned to Windows each time because several vital programs I use in Windows could not be run in Linux or substituted with a Linux alternative - A professional CAD program and Microsoft Outlook in particular.
I know that the CAD program runs perfectly in a virtual Windows machine and the advent of WinBoat has now made that approach remarkably simple to set up, so I do not have to learn a new drawing paradigm.
Microsoft are about to eliminate Outlook, so finding a program that will completely substitute for Outlook formed both the major driving force behind wanting to move to Linux and the only remaining barrier to running a Linux machine. But, I am now satisfied that Evolution can do everything that Outlook has done for me for since 1997, including carrying the contents of my huge .pst file and opening and closing much faster than Outlook does.
I am in last process(takes 30 days Thanks Microslop) deleting my last outlook addresses I have switched to yahoo mail it has all I want or need and with this final removal I will finally be free of any Microslop goodies.... :partying_face:
