Zorin OS recovery
How can you recover Zorin OS? This is after installing a Nvidia card (with compatible drivers - triple checked) according to forum suggestions, however the screen stays black - no matter what. All I have is (Duplicity?) backups.
Zorin OS does not have a recovery function like Windows because there is no need for it. Just reinstall the OS, restore your user directory from the backup, reinstall apps, then you're done.
Cheers, will try that
So far it seems to work, thanks. However, I do have a nvidia graphics card but in the system is my old, AMD RX 570, registered. How do I change that?
See if this askubuntu thread helps:
Moved to General Help. Please be aware of where you create posts... this is not a tutorial.
