Zorin OS Stuck on White Screen After Login Any Solutions?
Hi everyone,
Iam facing an issue with Zorin OS where, after logging in, Iam stuck on a white screen. The system seems to be running in the background, as I can navigate using keyboard shortcuts, but nothing is visible on the screen.
I have tried restarting the system and checking my graphics drivers and display settings, but the problem persists.
Has anyone else dealt with this kind of issue before? Could it be related to a recent update, a configuration issue, or a driver conflict?
Any troubleshooting tips would be really appreciated!
Thanks in advance for your help!
Hi,
Maybe it’s a good idea to add system specs as well ? What os your using core/pro ? We need more details. Did this happen after a fresh install ?
A couple of Questions:
  • Do You use a Dual-Boot System?
  • If yes: Is Fast start-Up in Windows turned off?
  • Are Secure Boot and Fast Boot in BIOS turned off?
  • Is Your BIOS in UEFI or Legacy Mode?
  • What Tool did You use to create the bottable USB Stick with Zorin on it?
  • Did You checked the Checksum of the ISO?
  • Do You use Nvidia Graphics?
  • If yes: Did You installed Zorin with Drivers or without?
