Zorin Pro 18 disable touchpad while typing
This option appears under Settings, Mouse & Touchpad, Touchpad: Disable Touchpad While Typing. It doesn't appear to work on my laptop; I find my cursor jumping to a different spot while typing. Related answers on the forum no longer apply (e.g., GNOME Extensions Touchpad Indicator is listed as Incompatible).
Thank You!
Maybe this could be a Replacement?
That does it! Thank you!
Good that it works for You. I will mark the Post as Solution.
