Zorin screens are inverted. Please resolve my issue
Gday @Fazeel1 , Welcome to the forum.
In setting/Display/Orientation change from flip to landscape.
Hope this helps
Note: if on Zorin Lite,
Goto Settings/Display/Rotation & Reflection: set to, " None".
Ok i see it's Zorin core & are you missing the option to change?
If so, try to restart laptop.
If no luck,
Please tell us how do you have this installed/running, Zorin OS.
Dual boot/clean install/live?
How long since you installed Zorin?
Could you please change your Profile to show which Edition of Zorin you have, thank you.
Also, please see:
I have edited the orginal title of this thread to describe the issue and to help future searches.
Zab.
:rofl:
This is an issue that I had on Windows and followed me till Zorin but happens on the CMOS webcam. Although I don't use it, if one day will happen that I need it I hope there will be a reasonable fix that don't need me to edit half system files manually. Let's see if your suggestions helped Fazeel1 to fix, this flipped screen issue is interesting.
Mr_Magoo has the Solution... Inverter Glasses ,,, hahahahahahaaaaaaaa
