When booting up this type of error shows everytime and then logging in. I don't know how to solve this error. Can anyone help me to solve from this type of error.
I believe you have no further problem while using the system?
You could try;
- Restart
- Enter in BIOS
Disable the Secure Boot
Save changes and exit. Restart the pc
Even so, it has to do with the bios settings, I believe you should look there. Do you experience further problem while booting, because of this message?
as stated by @dasjdoom it's attempting to find your partition in linux. try
sudo fdisk -l to locate it and upload the info
looking for something:
/dev/sdb1 34 32767 32734 16M Microsoft reserved
/dev/sdb2 32767 1025777663 1025744896 489,1G Microsoft basic data
/dev/sdb3 1025777663 1026828287 1050624 513G EFI System
/dev/sdb4 1026828287 1953523711 926695424 441.9G Linux filesystem
If you get it resolved or not let us know as it will help others in future
I would reinstall Zorin OS in this case.
It has the hallmarks of a corrupted file. It may be due to a bad sector on disk.
But it could also be due to a corruption during download that installed to disk.
After reinstalling there is no problem @Aravisian @Bubby @dasjdoom. May be in future if the problem may arises I will inform you
