Anyone else see something similar on their panel (16 Pro Lite).
I was looking at my wifi settings, then closed and noticed the panel.
Only thing open at that time was just Brave.
Are there any taskbar setting window like it was in GNOME Version? If yes, then you can disable the option which enables the name showing of the application.
alt+F2
Then
xfce4-panel --restart
Then please open a bunch of stuff and close it out and test.
Seems to have worked. Thanks yet again...lol
