A Linux desktop simulator and code/installer generator for right-click context menu shortcuts
An interactive Linux desktop simulator and code/installer generator to create custom right-click context menu shortcuts for apps, documents, scripts, and web links across GNOME, KDE, Mint/Cinnamon, and XFCE.
This is more for power users but its fun and its real!
Feel free to use this modify or just trash bin it but if want to learn under the hood how powerful linux is check it out. ITs well documented and yes it works on Zorin os
Have fun
Highlights
  1. Interactive Desktop Simulator:
  • Right-click anywhere on the desktop to test the native context menu with :high_voltage: Create Quick Shortcut...
  • Search catalog of 25+ popular Linux applications, documents, web URLs, and shell scripts.
  • Switch themes between Ubuntu GNOME, Linux Mint Cinnamon, and KDE Plasma 6.
  • Test the GNOME security gate: right-click any icon to toggle Allow Launching (gio set metadata::trusted true).
  1. Real-World 1-Click Installers:
  • Linux Mint & Cinnamon (Nemo Action): 1 command creates ~/.local/share/nemo/actions/create-shortcut.nemo_action.
  • Ubuntu & GNOME (Nautilus / DING): 1 command creates ~/.local/share/nautilus/scripts/⚡ Create Shortcut.
  • KDE Plasma (KIO ServiceMenu): 1 command sets up ~/.local/share/kio/servicemenus/create-shortcut.desktop.
  • XFCE (Thunar Custom Action): User customizable action for folder backgrounds.
  • Universal Python GUI Script: Zero external dependencies (uses standard tkinter).
  1. Put Shortcuts on Your Real Desktop:
  • 1-Second Terminal Command: Copy the generated command into your terminal (Ctrl + Alt + T).
  • File Download: Download the .desktop file, move it to ~/Desktop/, and right-click "Allow Launching".
  1. How to Share with Others:
  • Option 1: Send the hosted web app URL (Zero installation required).
  • Option 2: Send the 1-line bash script.
  • Option 3: Download and share install-desktop-shortcuts.sh via USB or email.
Quick Reference: 1-Click Terminal Shortcut Creator
To create an instant desktop shortcut in Linux without opening any file manager:
cat << 'EOF' > ~/Desktop/DesktopLinkStudio.desktop [Desktop Entry] Version=1.0 Type=Application Name=Visual Studio Code Exec=code %F Icon=vscode Terminal=false Categories=Development;IDE; StartupNotify=true EOF chmod +x ~/Desktop/DesktopLinkStudiodesktop gio set ~/Desktop/DesktopLinkStudio.desktop metadata::trusted true 2>/dev/null
License
Apache-2.0
You should format the last Part. Also You wrote:
but there is no such File:
Also the mentioned:
I didn't saw.
To be honest: You have nice formatted Steps here but the Content with the Explanations, I don't find really good.
Alternatively, users could just go to
distrosea.com and see what other DEs are out there.
this program creates the sh file for you incase you didnt read ..
I have written every single instruction, command, and guide into a complete Markdown file: /LINUX_SHORTCUT_GUIDE.md (as well as updating the root /README.md ).
You can also download this file to your computer at any time using the new "Guide (.md)" button in the app header and footer.
What Is Included in LINUX_SHORTCUT_GUIDE.md:
  1. How Linux Desktop Context Menus Work :
  • Modular breakdown of Nemo Actions (Mint/Cinnamon), Nautilus & DING Scripts (Ubuntu/GNOME), KIO ServiceMenus (KDE Plasma), and Thunar Custom Actions (XFCE).
  1. Quickest Way: Put a Real Shortcut on Your Desktop Now :
  • Copy-paste terminal snippets for Native Apps (VS Code), PDF Documents, and Web Links.
  1. Permanent Setup by Desktop Environment :
  • Linux Mint & Cinnamon : Exact .nemo_action file and location (~/.local/share/nemo/actions/).
  • Ubuntu & GNOME : Exact Zenity/GTK script and location (~/.local/share/nautilus/scripts/).
  • KDE Plasma 6 & 5 : Exact KIO ServiceMenu file (~/.local/share/kio/servicemenus/).
  • XFCE : Exact Thunar UCA configuration.
  1. Universal Portable Python GUI Shortcut Maker :
  • Complete Python 3 script using standard built-in tkinter (zero external dependencies or pip installs needed).
  1. Freedesktop .desktop Specification Cheat Sheet :
  • Standard templates for Native Applications, Flatpak apps (flatpak run ...), Snap packages, Documents/PDFs (xdg-open), Web Links/PWAs, Terminal Commands (htop), and Wine/Windows programs.
  1. The Two Essential Linux Security Rules :
  • Why chmod +x is required so double-clicking doesn't open a text editor.
  • Why gio set metadata::trusted true is required in GNOME 40+ to remove the "Untrusted Desktop Launcher" warning.
  1. How to Give This to Other People & How They Run It :
  • Option 1 (Web Link) : Send the URL https://ais-pre-guzn6rwxuhckwvhvkcryh3-894648866967.us-east1.run.app → they open in any browser and click "Real PC".
  • Option 2 (1-Line Command) : Command they paste into terminal (Ctrl+Alt+T) to enable the right-click menu instantly.
  • Option 3 (Offline File) : Send install-desktop-shortcuts.sh via USB/email → they right-click, check "Allow executing file as program", and double-click to run.
  1. Troubleshooting & FAQ :
  • Solutions for unclickable launchers, gear icon replacements, custom image paths (~/.local/share/icons/), and terminal wrappers.
